Home Forums Products Stompboxes H9 with Disaster area DMC4 as a midi controller… how to set up expression control? Reply To: H9 with Disaster area DMC4 as a midi controller… how to set up expression control?
#149958
camn
    Did you work this out Jared?
    You didnt mention the generation of your DMC- but in the Gen3 you need to setup the “R CH” setting on your DMC to whatever channel your H9 is on.
    Then you need to Set the H9’s Expression Pedal Value to CC 48.
    It should work after that. Holla if it doesn’t.
    Bohan-  The DMC has a roller on the side of the device as a factory option, which is what he was refferring to. It can obviously only send MIDI, and cannot be plugged into the H9 independently.  Also the Disater Area line in general is pretty inflexible about what MIDI messages it sends. But their docs are pretty clear about the setup required on the H9. Obviously this is Disaster-Area stuff, and not H9 stuff.. so there is no reason you would know it… but file it away in your brain if you want?
    Also FOR EVERYONE:
    DIsater Area Designs Gen3 DMC3XL and DMC4 pedals call for the following settings on the H9:
    Tap Tempo to MIDI CC 44
    Performance Switch to MIDI CC 46
    Toggle Tuner to MIDI CC 69
     Activate to MIDI CC 42
    Set Expression Pedal Value to CC 48
    MIDI Receive Channel to 1, 2, 3, or 4 for device A, B, C, D
