Home › Forums › Products › Stompboxes › Pitchfactor jumping to different algorithms when changing presets › Reply To: Pitchfactor jumping to different algorithms when changing presets
August 20, 2018 at 7:17 pm
#149960
Hi – never heard of anything like you describe. I'm doubtful, because algorithms do not load instantly (unfortunately) so it seems unlikely that it would switch between algorithms as you describe. But, that aside, I would suggest that:
1) You try different bypass modes, in case what you are hearing is a bypass artefact.
2) If the above is not helpful, try "Restoring Factory System Settings" as described in the UM.
