Reply To: Pitchfactor jumping to different algorithms when changing presets
Home Forums Products Stompboxes Pitchfactor jumping to different algorithms when changing presets Reply To: Pitchfactor jumping to different algorithms when changing presets
#149962
Using "Restoring Factory System Settings" will not delete your presets.
If you are using MIDI to change these presets, can you try the same thing with the switches and see if you get the same result ?
