Home › Forums › Products › Stompboxes › H9 Wish List › Reply To: H9 Wish List
Hi Eventide,
Just got the H9 pedal two weeks ago, and still learning how to work with an expression pedal, including Control Input Volume and Control Output Volume.
My question is this: if a linear taper is usually desired for expression effects but an audio taper is desired for volume effects, would it be possible to “map” the signal from a linear expression pedal to the appropriate taper for the parameter?
For example, I want to use an expression pedal with a linear pot to control the Mix linearly but the Output Volume exponentially (audio taper). I imagine someone might be interested in something similar if they’re using an audio taper volume pedal (and want to control a parameter linearly).
Yes !!!!!
