Home › Forums › Products › Stompboxes › Need to replace encoder knob pot, but I don’t know which part to buy › Reply To: Need to replace encoder knob pot, but I don’t know which part to buy
August 31, 2018 at 1:10 pm
#150020
Your picture looks like one of the knob pots, but your description suggests that you refer to the encoder. If the second, try adjusting the click – lever off the round disk at the top of the knob, and you will see a brass knob – slacken this off slightly and pull up the knob a smidge, then tighten the knob. If this then clicks as it should, well and good, otherwise support@eventide.com.
