Home › Forums › Products › Plug-Ins › Elevate Plugin does not load Ableton10 › Reply To: Elevate Plugin does not load Ableton10
I’ve installed the Elevate master bundle. Saturate, EQ, and Punctuate all show up. However, Elevate does not. What could be wrong? I am using VST2 on Ableton10 in Windows
Hi bjacobs,
I’m not having any problems with the current Elevate (1.5.7) on Windows on Ableton 10. Can you double check and make sure the Newfangled Elevate.dll is in the VST folder that Ableton is scanning?
Thanks,
Dan
Hi Dan,
I can verify that .dll is in the folder. And I can verify that I am on 1.5.7. The only thing I haven’t tried is restarting my machine, which I can try when Im home for work. If that doesn’t work are there any logs or anything I can send to you guys?
