Home Forums Products Stompboxes H9 Pitchfuzz lag when switching via midi Reply To: H9 Pitchfuzz lag when switching via midi
#150188
actioncamp
    I will chime in on this to offer an additional scenario I’m running into within the Pitchfuzz algorithm itself.
    If I make the hotswitch or an expression pedal just turn the pitch mix up or down (to engage and disengage the octave but keep the fuzz on) it still
    has a lag. confirmed via midi control that other algorithms like wah, modechoverb, etc where i change multiple parameters don’t have that lag time with the same midi expression pedal.
    I know it’s a heftier plugin but if Eventide staff ends up having the time/resources you might want to look at revising the code of Pitchfuzz as a target for the next update. I know it got a fairly quick overhaul between the Namm show and release so maybe something is choppy in there that could be improved. I’ve just gotten used to my transition a little early to compensate for the switch but obviously it’d be nicer if it could react in real time to really ride the delays and pitches with an expression input.
