Home Forums Products Stompboxes Battery or Phantom Powered MIDI Controller Reply To: Battery or Phantom Powered MIDI Controller
#150230
    Thanks
    question wrote:
    Phantom power insertion cables are $20-30ish (there are various types around) and probably the cheapest and easiest way to power up the Morningstarfx the way you want (i.e. through its MIDI port). Again, it’s better to check with the respective manufacturers for compatibility.
    Best of luck in your pursuit anyway : )
