Home Forums Products Stompboxes H9 Output Stops Completely Reply To: H9 Output Stops Completely
#150232
    Thanks. Is it possible to turn off (bypass) H9 using Tech21 Mongoose or is it always a preset on even if you click the same button twice? I guess two things not possible with it is bypass H9 and turn on the tuner.
    ratliffm wrote:
    I have not reproduced the problem since I unmapped the CC #32 and #33 signals on my H9. My MIDI Mongoose has worked flawlessly.
