Home Forums Products Stompboxes Pitchfactor using external expression pedal and midi controller? Reply To: Pitchfactor using external expression pedal and midi controller?
#150255
guitarplyr
    brock wrote:
    Assign your MIDI CC# to PED as a destination on the PitchFactor.  Anything you’ve mapped to the expression pedal in a preset will be controlled by that.  Savable per-preset.
    Unfortunately I am not in front of my rig atm, but just to clarify as long as I assign a CC to the expression pedal thru the Midi Raider I can now use it as if it was directly plugged into the Pitchfactor? Sorry if its obvious, but as an expression pedal novice I just want to make sure I got it. I honestly dont know why I didnt do this years ago as it really opens up sooo many possibilities of sounds!! My thanks and gratitude.
