Home Forums Products Stompboxes Pitchfactor using external expression pedal and midi controller? Reply To: Pitchfactor using external expression pedal and midi controller?
#150258
guitarplyr
    guitarplyr wrote:
    brock wrote:
    Assign your MIDI CC# to PED as a destination on the PitchFactor.  Anything you’ve mapped to the expression pedal in a preset will be controlled by that.  Savable per-preset.
    Ok, but do I have to map each knob to the pedal or is there a way to assign the knobs as if the expression pedal was plugged directly into the Pitchfactor? On my delay pedal there is no mapping involved once I give it the CC command. You turn the knobs to the parameters you want at heel, then toe and save it. You can do that on the Pitch if the pedal is plugged directly into it but when going thru the Midi Raider,  I assign the CC message but still have to go in and assign each knob individually. Any way to avoid that?
