Home Forums Products Stompboxes Pitchfactor using external expression pedal and midi controller? Reply To: Pitchfactor using external expression pedal and midi controller?
#150262
guitarplyr
    Just a bump as my last post may have been a little confusing as it posted in all quotes, including my question.
    I have already assigned a CC# to PED as a destination but it seems I still have to map the parameters to the pedal and then likewise in the Midi Raider.
    With my delay unit, once I assisgned the CC# to the expression pedal in the Midi Raider I can control the entire delay as though the expression pedal was plugged directly into it. I can adjust each parameter with the knobs and hit save and thats all there is to it. No mapping, which saves A LOT of time considering you have to program the Pitchfactor AND the Midi Raider. Is there any way to have the Pitchfactor behave as if the expression pedal is plugged directly into it? Thanks!
