Home Forums Products Stompboxes H9 Help! Can’t Select “No mapping” on Aux Switch Mappings 5.4.1.7 iOS12 Reply To: H9 Help! Can’t Select “No mapping” on Aux Switch Mappings 5.4.1.7 iOS12
#150267
[/quote]
Hi, I just tested it on my iPad with iOS 12. I can select “No Mapping”. You need to scroll the options wheel slowly. You should be able to choose “No Mappings”.
BTW, you can also set Aux Switch mappings on the unit. You can go to the setting mode by pressing and holding the right footswitch and the HOTKNOB.
[/quote]
Thanks for the reply. It would not let me select “No Mappings” for any of the settings. I tried slow, rebooted everything.
I’ll try to see if I can clear it on the pedal itself.
