Home Forums Products Stompboxes H9 Help! Can’t Select “No mapping” on Aux Switch Mappings 5.4.1.7 iOS12 Reply To: H9 Help! Can’t Select “No mapping” on Aux Switch Mappings 5.4.1.7 iOS12
#150273
Ok, it seems that if I select very slowly(as you suggested) and let go just before it gets to “no mapping” it will select this on ios12. It seems like the issue is that the UI for the scrolling has changed and it “bounces back” to “foot switch 1” if I scroll all the way up to “no mapping”.
I am trying to set a footswitch to switch between H9 effect on and bypass.(with the kill dry enabled)
Settings are:
  • “Bypass” set to Sw1
  • “Bypass Enabled” – Yes
  • “Bypass Mode” – DSP
  • “Kill Dry Audio” – Yes
The footswitch now does not do anything. Yesterday when I had multiple things mapped to Sw1 it would switch the bypass but only about 50% of the time.
Any ideas?
