Home Forums Products Stompboxes Multiple RCV Program Change Maps Reply To: Multiple RCV Program Change Maps
#150442
bohan
    aonascimento wrote:
    Is that possible without the need to externally save/export the current
    config? In other words, is that possible changing the RCV MAP on the fly
    without having to connect to a pc and loading a previously saved MAP?
    No, you can only assign one RCV Map. But here is something you can do:
    PC #00 -> 1:1
    PC #01 -> 2:1
    PC #02 -> 3:1
    PC #03 -> 4:1
    PC #04 -> 5:1
    With footswitches on the TimeFactor, you may be able to easily switch to 10 presets.
    Is it possible changing the RCV MAP on the fly without connecting to a PC?
    Yes. You can change the MIDI PC RCV Mapping on the unit in the Settings->MIDI->RCV Map menu.
