Multiple RCV Program Change Maps
Home Forums Products Stompboxes Multiple RCV Program Change Maps
    • #115030
      aonascimento
      Hi. I recently acquired a TimeFactor stomp due to all the control it provides to its features, and it’s really awsome indeed. However, I came across an issue that is bugging me because I could not find any answer through the web.
      My MIDI controller is very limited at the number of program changes it sends and I was hopping that TimeFactor allowed me to create more than one RCV Map. Eg:
      RCV MAP #01
      PC #00 -> Bypass
      PC #01 -> 1:1
      PC #02 -> 1:2
      PC #03 -> 2:1
      PC #04 -> 2:2
      RCV MAP #02
      PC #00 -> Bypass
      PC #01 -> 4:1
      PC #02 -> 4:2
      PC #03 -> 5:1
      PC #04 -> 5:2
      That way I could use the same program changes my controller is capable of
      sending to have multiple multiple presets in different contexts/bands, etc.
      Is that possible without the need to externally save/export the current
      config? In other words, is that possible changing the RCV MAP on the fly
      without having to connect to a pc and loading a previously saved MAP?
      Thanks in advance.
    • #150442
      bohan
      No, you can only assign one RCV Map. But here is something you can do:
      PC #00 -> 1:1
      PC #01 -> 2:1
      PC #02 -> 3:1
      PC #03 -> 4:1
      PC #04 -> 5:1
      With footswitches on the TimeFactor, you may be able to easily switch to 10 presets.
      Is it possible changing the RCV MAP on the fly without connecting to a PC?
      Yes. You can change the MIDI PC RCV Mapping on the unit in the Settings->MIDI->RCV Map menu.
      • #150443
        aonascimento
        PC #00 -> 1:1
        PC #01 -> 2:1
        PC #02 -> 3:1
        PC #03 -> 4:1
        PC #04 -> 5:1
        That was exactly what I intended to do, thanks for the suggestion by the way. The point is that this is just one MAP, and I would need a completely different MAP for another band situation (eg. play in a cover band, and play in an independent  band, or with acoustic set), with the same program changes pointing to different bank:presets.
        That mainly is because of my controller PC number limitation.
        I meant the whole RCV MAP like MAP 01, MAP 02, MAP 03…  But as you said, only one map can be assigned at a time.
        I suppose I’ll have to load saved maps for every different gig.
        Thanks for the reply.
