Home › Forums › Products › Stompboxes › The new HotSawz algorithm is available for the H9 now! › Reply To: The new HotSawz algorithm is available for the H9 now!
#150518
Megalodon
    Can you restore your H9 and try updating again? To restore System settings, power up the H9 while simultaneously pressing the Right
    Footswitch and the HOTKNOB button until [CLEAR] is displayed.
    If that still doesn't work, please try updating the H9 using a USB cable on your PC.
    [/quote]
    No luck. I used a USB, direct updater, and the update/file sent by support. Everything worked fine before the update. Now when it is powered up it only goes to the update screen and takes a lot longer to start up then before. When in the update process it will get to “write” at 1%, the pedal will display BAD, get a communication error 3 on the app/update, then the pedal displays READY. I’ve tried the previous update, as well. It’s pretty much bricked right now. No luck with initiat or restore either.
