Home › Forums › Products › Rackmount › Wiring of the DB25 analog audio connectors › Reply To: Wiring of the DB25 analog audio connectors
November 13, 2018 at 2:07 pm
#150591
Ok, cool…
Do you know if pin 13 is common ground ?
If so i would use that as the return line on the NMJ6HC-S
So the signal that is on all three pins when nothing is inserted.
