Home Forums Products Stompboxes H9 with boss ES-8; mono/stereo routing Reply To: H9 with boss ES-8; mono/stereo routing
#150619
bohan
    davebrubaker wrote:
    Does the H9 detect the mono (or stereo) input based on if a plug is inserted, or if there is an input signal in the channel?
    Yes, the H9 detects the mono/stereo inputs based on if a plug is inserted.
    If you want to run 3 H9's stereo effects, you may just put the third H9 after the output of your ES-8. You may use MIDI to control its on/off and switch presets.
