Home › Forums › Products › Stompboxes › H9 Hotswitch/Performance Switch via MIDI (acting inconsistent?) › Reply To: H9 Hotswitch/Performance Switch via MIDI (acting inconsistent?)
        November 23, 2018 at 9:00 am
        #150671
So the Hotswitch/Performance switch will work identically across the Space, TF, PF, and MF algorithms, with the same CC message value (between 64-127) toggling between on/off? Or do I still need to assign two switches for turning the hotswitch on and off as the CC value for “off” is between values 0 and 63?
