Home Forums Products Rackmount H3000D-SE that sounds “thin”.. Reply To: H3000D-SE that sounds “thin”..
#150691
tmoravan
Note that the H3000 series has the XLR wired as pin 3 hot compared to other audio products (and the eventual de facto standard of pin 2 in the US).  So if you connections eventually get unbalanced and you’re mixing in the effected audio with the dry signal then you’ll thin out the sound and hear something similar to what you describe.
Try running a 100% wet into both and do not mix any dry signal in direct from the source and compare.
