Home › Forums › Products › Stompboxes › Broken SawTooth – 66 HotSawz Presets › Reply To: Broken SawTooth – 66 HotSawz Presets
That is a ballsy title. My expectations will be really high. ![]()
Less ballsy than most, I imagine. And I really don’t want to imagine. I try to give presets unique, yet descriptive names. Those descriptions might only make sense to me; filtered through my sense of humor.
Let’s face it: Many of these presets are intentionally weird. Showcase-y. I tried to balance that with bread ‘n’ butter presets. Oddly enough, I’m finding those roles often reversed now, as I use them more.
I mentioned the expression pedal integration in passing. For a few presets, that might only mean subtle MIX or rate changes. But I think the EXP PED variations are key here. In most cases, the intent is to dynamically switch between two distinct synth types, or programming extremes. Play it like a volume pedal.
If no expression pedal is available, it might be worth dialing up the HotKnob, or ribbon strip in H9 Control. There’s a lot of fine-tuning to be had in the ‘morphing’ positions between Heel & Toe.
