Home Forums Products Stompboxes The new HotSawz algorithm is available for the H9 now! Reply To: The new HotSawz algorithm is available for the H9 now!
#150723
jbradwilson
    Finally figured out the issue of no sound from the Hotsawz algorithms.  I was connecting the H9 to the effects loop of a Headrush pedalboard with 4 cables; 2 sends and 2 receives.  The loop was not set for a stereo send.  Even though every other algorithm worked, Hotsawz would not until I set the send as stereo.  I also found I could disconnect one of the sends and make it work in mono, but if both send cables are connected both sends must have signal.
