Home Forums Products Stompboxes The new HotSawz algorithm is available for the H9 now! Reply To: The new HotSawz algorithm is available for the H9 now!
#150728
kinkyroy
    gkellum wrote:
    kinkyroy wrote:
    however to the sick sick sounds , I playing on it on 4 strings bass, a p-bass by fender and always having that bammer glitches
    I’m not sure I understand what you’re trying to say here.  You’re getting glitches with HotSawz?
    Do you have you H9 set to “Bass” as the source instrument by the way?  You can check this setting by clicking on the Pedal button in H9 Control’s bottom bar, go to “General Settings”, and go to “Source Instrument”.  Setting the source instrument to “Bass” will cause the H9 to track low frequency bass notes better.
    It is set up as bass and still the glitch are coming all the time?!
