Home Forums Products Rackmount H3000D-SE that sounds “thin”.. Reply To: H3000D-SE that sounds “thin”..
#150731
Foster
    DGillespie wrote:
    I don’t have an H3000 in front of me at the moment, but from my work on the H3000 plug-ins we did there’s no noticible tonal difference with any of the H3000’s I tested against.  It might be important to make sure you’ve got the levels set correctly on your H3000, there’s a level setting guide in the original manual here: https://www.eventideaudio.com/support/downloads/h3000-series-user-manual
    I also don’t recall if the H3000 had a pre-emphasis setting, but if so this could explain what you’re hearing.  Try turning that off if there is one (though I don’t think there is).
    If it’s none of these things, and if the tonal difference is significant, I think it’s most likely your H3000 needs calibration or repair.  There is a calibration procedure in the service manual here: https://www.eventideaudio.com/support/downloads/h3000-service-manual, or the Eventide support folks can help refer you to a qualified repair tech.
    Good luck,
    Dan
    Hi Dan,
    thank you for your reply, I didn’t find a pre emphasis to switch off on the H3000..  and I’ve paid attention to use the correct levels too, so I’m thinking that maybe my H3000 needs a recalibration as you suggested.. I’ll ask my tech to do this procedure and hope to solve this problem.
    I’ll let you know ..
    Thx
    Foster
