Home Forums Products Stompboxes Pitchfactor single repeat pitch shifted delay Reply To: Pitchfactor single repeat pitch shifted delay
#150892
    I'm not a PF expert, so please forgive me if I  am wrong or if this is too obvious. (Those who know are probably enjoying their time off).
    Seems like you need a simple shift, with DELAY set to 0.5 seconds, and MIX set to 50/50. Then, the dry signal gives you your A and the wet signal gives you your C.
