Home › Forums › Products › Stompboxes › Pre/Post Routing Noise Issue › Reply To: Pre/Post Routing Noise Issue
January 8, 2019 at 7:37 pm
#150946
ill_clinton wrote:
I've swapped pedals, cables, power sources. I'm stumped.
When you insert your stompbox into H9's Pre/Post loop, does toggling Pre/Post affect the noise? What if you bypass the stompbox while toggling Pre/Post?
I don't know…If H9 works fine on its own in either Pre or Post, I don't think it's H9's problem.
