Home › Forums › Products › Rackmount › H9K – SPDIF 96Khz BUG › Reply To: H9K – SPDIF 96Khz BUG
#151211
    Note that S/PDIF does not always work well at 96K due to ground noise (AES is balanced and floating so does not have this problem).
    Try and keep your cables short and high quality, and ground the units to the same point (usually a common power strip).
