Home › Forums › Products › Stompboxes › two H9s not sync together › Reply To: two H9s not sync together
#151255
    MIDI clock does not have an "on the beat" signal. It is just a sequence of pulses that indicate the tempo.
    In some cases you can use a MIDI start signal to indicate the beat, but in many cases all you can hope is that the tempos remain the same.
