Home Forums Products Stompboxes Does H9 input meter do anything? Reply To: Does H9 input meter do anything?
#151267
Boynigel
    bohan wrote:
    Boynigel wrote:
    so the H9 input meter must have quite the early warning for clipping?  is there a “known” db value as to how much would damage the pedal?  i’m a little concerned, again, because i’m smacking the front end of my amp pretty hard at times via clean boost and OD, and the H9 is in my signal chain after the clean boost/OD.
    Hi, it’s OK if the input LED is lit occasionally. Clean boost and OD won’t damage the pedal. As long as the LED is not always lit and you are fine with the sound, you don’t need to worry about it.
    It’s lighting with every note attack, then after a second it goes out.  that said, if i’m chugging chords it’s pretty much staying lit.  still an “okay” scenario?  interestingly,  on the actual pedal the red peak light comes on when the app’s peak light isn’t.  that said, the peak meter on the app isn’t far behind the pedal- usually one meter light block away.  could 4CM be creating/contributing to the peaking?  i don’t recall ever having this issue back when i used the pedal exclusively in my amp’s fx loop.
