Home › Forums › Products › Stompboxes › H9 Midi Using Ground Control Pro – Load Preset › Reply To: H9 Midi Using Ground Control Pro – Load Preset
#151303
    You say "Right now, I can only get the H9 to load unengaged if I have the preset saved as unengaged". Assuming by "engaged", you mean "active", this is how the unit is designed to work.
    It might be helpful if you could say what brands work "flawlesly", and in what way they do this.
