Home › Forums › Products › Stompboxes › H9 Midi Using Ground Control Pro – Load Preset › Reply To: H9 Midi Using Ground Control Pro – Load Preset
February 18, 2019 at 10:08 pm
#151323
If you set CC102 to “toggle bypass and active” you should be able to get pretty similar function to the Strymon… but you might need the GC to send 127 each press. *
On the H9 its all under PEDAL–>ASSIGN MIDI CC MESSAGES
*dont have a GC, havent checked 🙂
