Home Forums Products Vsig and Preset Development VSIG-H9000-Send to H9000 greyed Reply To: VSIG-H9000-Send to H9000 greyed
#151357
jbamberg
    macgee wrote:
    I've installed VSIG and it's running and I've created a basic preset however "Send to H9000" is greyed out.
    Usually that menu item is enabled if you have an algorithm with some modules hooked up.  (It won't allow you to upload an empty sigfile).
    The transfer mechanism uses the network.  You don't need to have emote connected when you transfer algorithms, as Vsig contains the network client itself.
    We should probably supply some example sigfiles to help people get started.  I'll see if we can sort that out soon.
