Home › Forums › Products › Stompboxes › Timefactor: is there a way to have default values and not the expression pedal ones when you turn on a preset? › Reply To: Timefactor: is there a way to have default values and not the expression pedal ones when you turn on a preset?
February 27, 2019 at 9:20 pm
#151391
The current expression pedal value is saved along with a preset.
Set the pedal position (or do it in H9 Control), then re-save the preset.
