Home › Forums › Products › Stompboxes › Timefactor: is there a way to have default values and not the expression pedal ones when you turn on a preset? › Reply To: Timefactor: is there a way to have default values and not the expression pedal ones when you turn on a preset?
February 27, 2019 at 11:29 pm
#151396
Yeah, I have to say… I don’t think I get that behavior.
When you call a preset… The algo doesn’t even know what the expression pedal value is until you move it.
Mine always load with the same ‘default’ values… That is – whatever I saved them with. Despite where the exp pedal landed from the last patch.
Are you sure the exp pedal isn’t jiggling or something? What is your setup?
