Home Forums Products Stompboxes Timefactor: is there a way to have default values and not the expression pedal ones when you turn on a preset? Reply To: Timefactor: is there a way to have default values and not the expression pedal ones when you turn on a preset?
#151399
camn wrote:
Yeah, I have to say… I don’t think I get that behavior. When you call a preset… The algo doesn’t even know what the expression pedal value is until you move it. Mine always load with the same ‘default’ values… That is – whatever I saved them with. Despite where the exp pedal landed from the last patch. Are you sure the exp pedal isn’t jiggling or something? What is your setup?
Hi, I use an Ernieball VPJR 25kohm, as suggested by Eventide. The pedal itself is working properly when rocked.
