Home › Forums › Products › Stompboxes › Timefactor: is there a way to have default values and not the expression pedal ones when you turn on a preset? › Reply To: Timefactor: is there a way to have default values and not the expression pedal ones when you turn on a preset?
February 28, 2019 at 5:09 pm
#151402
stratboy wrote:
Another way to say this: right after activating a preset, I'd like having the values changing only after (and if) the expression pedal is moved.
Is it possible?
Yes. TimeFactor works in the way you described. If your preset was saved with FEEDBACK 50, when you load it the FEEDBACK will be 50 if you don't move your expression pedal.
