Home Forums Products Stompboxes Timefactor: is there a way to have default values and not the expression pedal ones when you turn on a preset? Reply To: Timefactor: is there a way to have default values and not the expression pedal ones when you turn on a preset?
#151403
camn
    Yeah… So what we are saying is this: your desired function is our normal operation.
    So this sounds like abberant behaviour.
    Can you take a video of the problem, including some shots of you H9 control window when you are flipping presets around?
    I’m thinking… Load preset ‘a’ with the exp all the way back… Push it all the way forward and leave it, change presets, reload preset ‘a’ with the exp all the way forward… And show us what happens in H9 control.
