Home › Forums › Products › Rackmount › Using Emote plug-in with Logic Pro X – I/O setting? › Reply To: Using Emote plug-in with Logic Pro X – I/O setting?
March 11, 2019 at 12:52 pm
#151460
there was no link so added it
Sorry there’s no audio or captions, time is short
Here’s the GS chat where we discussed it and clarify a few things – it’s not fully comprehensive but should help
https://www.gearslutz.com/board/showpost.php?p=13857101&postcount=204
It could be that you set the sample rate on the H9K but then you have to in DAW, set the Sample rate – If the sample rate’s match you have to change the SR to something else and then back again. It’s a current nuance (or nuissance) so hope this gets resolved and the video shows this.
