Home Forums Products Stompboxes Controlling Strymon Sunset with H9 (midi) Reply To: Controlling Strymon Sunset with H9 (midi)
#151597
    Good to know about the Class Bliss compatibility.  Some of my newer devices almost demand MIDI control.  The trend is toward multi-function everything on the front panel, less connectivity, in smaller packages.
    Two thoughts on the Event Processor (Plus):
    • You may be able to fit it under that board.  It’d be tight.  That’s where I’ve mounted mine.  You really don’t need any access to it, other than the MIDI-DIN cables.  Once you program it, it’s done (until you need another set of functions).  The Plus version is a little more costly, but I’ve found that I end up using the additional Settings.
    • If you’d like to see a programming application, here’s a local link.  It’s easier than it appears.
    • https://www.eventideaudio.com/comment/25417#comment-25417
    • Now, the big one.  5V power over MIDI, from the [H9 -> EPP -> Infinity].  Not all H9’s do it.  All of mine don’t.  The DIY fix was never detailed here on the forum.  Apparently, Serial #16329 (and above) is the dividing line.
    • Here’s the background on that info:
    • https://www.eventideaudio.com/comment/26887#comment-26887
    • https://www.eventideaudio.com/comment/22601#comment-22601
