Home › Forums › Products › Rackmount › H9000 1.1 Public Beta › Reply To: H9000 1.1 Public Beta
im using WiFi via the supplied USB WiFi dongle. the mac may be going to sleep around the time of the disconnection, i've not looked at that correlation but will do so.
the loss of the connection itself is no major issue but what i notice is, after a loss of connection and then reconnecting, the reconnection usually drops out a lot more frequently and whilst in the middle of using Emote..
again, nothing life stopping but room for improvement.. ill see if i can switch to using Wired to get around it
OK, it sounds like we need to be a bit more resilient when using WiFi. A wired network will have less (generally zero) packet loss so is likely to work better. Thanks for the report.
