Home Forums Products Stompboxes Can I take tap tempo into H9 and send out as MIDI clock? Reply To: Can I take tap tempo into H9 and send out as MIDI clock?
#151679
bohan
    lordradish wrote:
    I've been doing a few things to get all of my pedals on my board in sync, and I have an external tap tempo I'd like to go into the H9. My pigtronix infinity looper, however, will only take a midi clock for tempo, so I'm wondering, is there a way to send the tempo out over midi on the H9 (based on the tap tempo in), and then send it to MIDI out, and if so, how would I do this?
    Yes. You may enable MIDI Output Clock. You can do so on your H9 or in H9 Control.
    On H9: Go to the setting menu by press and hold the HOTKNOB and the right footswitch, then go to MIDI -> CLK.OUT -> ON
    In H9 Control: See my attachment.
