Home Forums Products Plug-Ins Blackhole Stereo-in mono-out Reply To: Blackhole Stereo-in mono-out
#151744
tlongabaugh
    The channel configurations of the plugin will depend on the track you use it on, and what DAW you are using.
    Some DAWs use stereo-in stereo-out only. Other DAWs let you select the format, based on if you are adding it to a mono or stereo track. It may also depend on how you have your bussing set up.
    What DAW are you using?
