Home Forums Products Rackmount H9000 1.1 Public Beta Reply To: H9000 1.1 Public Beta
#151796
cbm
    macgee wrote:
    cbm wrote:
    macgee wrote:
    I’m using that setup, working flawlessly actually but took a little setting up
    H9000-specific setting up, or general setup? If I already have it working use with the Orville, do you think that there are flaming hoops to jump through to get the H9000 working with it?
    Quite simply you just need to install VSIG for H9000 (assuming it has same dependencies H8000) along with latest database and also install Apple’s Bonjour Printer which allows for discovery and then you should be set. VSIG communicates to H9000 over network so preferably use wired network
    Do you have an H9000 yet? Try that first and see how you go, any questions I’m happy to help
    That doesn’t sound bad at all. I’m still testing the waters before picking up an H9000.
