Home › Forums › Products › Stompboxes › 2 h9’s tap tempo › Reply To: 2 h9’s tap tempo
#151804
cljfford
    nickrose wrote:
    There are a few things to change.
    1) Make sure the sender is set to MIDI/OUTPUT=XMT.
    2) Make sure the sender is set to MIDI/CLK.OUT=ON.
    3) Make sure the receiver is set to MIDI/CLK.IN=ON.
    4) Connect a DIN5 between MIDI OUT on the sender and MIDI IN on the receiver.
    That should do it.
    I’m not having the expected result when I follow the steps above and wonder if anyone can help me figure out what might be wrong. The receiving H9 does not adjust, i.e. speed. I know I have a working DIN5 cable between them because the receiving H9 can get messages from my MIDI foot controller. But in that case, my 1st H9 is set to MIDI/OUTPUT=THRU+MIDI CLOCK and the tap tempo is generated by the foot controller, sending a CC# to each H9’s MIDI Channel.
    I’d like to be able to adjust both tap tempos from the iOS app but can’t get the Control app Tap to adjust the tempo of the recieving H9. Is there anything else I should look at?
    If it is relevant, the reciving MIDI Clock settings on the recieving H9 are:
    Enable MIDI Input Clock= NO (I’ve tried YES with no success)
    Enable MIDI Clock Filter= NO
    Enable MIDI Output Clock= NO
