Home › Forums › Products › Stompboxes › H9 presets/settings for a Zappa lead tone? › Reply To: H9 presets/settings for a Zappa lead tone?
You’d think I could find them easily. I did run across a “Ship Ahoy Flange’ preset, that sounded like I tweaked it into an Oberheim VCF-200 [sequenced filter]. It will be faster to create a base preset to work from.
Relatively mild envelope settings to start with here. You can do much the same with the CHORUS or PHASER algos (and others), or by changing the FLANGER TYPE here to THRU-0. Different core emulations of effects processing can yield similar, but never identical, results.
Four interactive parameters here will determine the overall ‘intensity’ of the effect:
SENSITIVITY tweaks are crucial to matching your input & playing style. INTENSITY and DEPTH increases will bring the dynamic effects forward. DELAY OFFSET [MODFY DLY O/P], as mentioned, is the ‘manual’ delay time. Increase or decrease that midpoint value for higher or lower sweeps in the apparent ‘pitch’.
The expression pedal mapping was added here, strictly to illustrate the most extreme sounding values. The lower row of FLANGER controls (or most any ModFactor algorithm) can be left at neutral settings, unless you want to fold in a little added modulation over the main envelope modulation.
Show More...Show Less...
