Home Forums Products Stompboxes Programming expression parameter ranges via Android H9 Control Reply To: Programming expression parameter ranges via Android H9 Control
#151877
bohan
    raal71 wrote:
    Haven't found a way to set different ranges for parameters to be assigned to EXP via the Android app.
    This worked fine on the Windows app, clicking the blue ribbons around the knobs. I thought I might be able to achieve the same thing with the XY Pad but I'm not finding this functionality either. What's up with the Android app?
    The Android app works the same way as the Windows app. You may use the ribbon to control the EXP, and use the two ribbon buttons to set the EXP mappings.
    Screenshot Image
    Screenshot Image
