Home Forums Products Stompboxes Programming expression parameter ranges via Android H9 Control Reply To: Programming expression parameter ranges via Android H9 Control
#151878
raal71
    Perhaps i should have been more explicit. I’m using the SP-H9 as expression pedal and would like to set specific parameter values for heel and toe position of the expression pedal. For example Mod Depth at 15 in heel and 55 at toe position, or mix 5 in heel and 40 in toe, ….
    In win i used to click and move the dots at the ends of the light blue colored ribbons around the parameter buttons. It is not clear to me how using the ribbon or the 2 ribbon buttons can address this need.
