Home Forums Products Stompboxes Question: How to setup H9 with PC audio interface (iConnectAudio4+) ? Reply To: Question: How to setup H9 with PC audio interface (iConnectAudio4+) ?
#151904
bohan
    Marcel wrote:
    Hmmm…..I have tried a lot of things, but I couldn’t make it work. What did work was: Keyboard audio > H9 > Audio Interface > PC Daw. No problem there, I did get a wet audio signal. But what I want, didn’t work, which is : Daw audio > interface > H9 > interface > Daw wet audio. Perhaps I should contact the iConnectivity forum.
    Yes. I believe iConnectivity can help you more on this. You need to do most settings in your DAW. Set the track that you want to apply H9's effects to iConnectivity's output, and record iConnectivity's input on a new track.
    iConnectivity's output -> H9's input
    H9's output -> iConnectivity's input
