Home Forums Products Rackmount H9000 : Parallel Delays : Delay 2 & 4 not working? Reply To: H9000 : Parallel Delays : Delay 2 & 4 not working?
#152012
zazula
    Thanks for checking out the session.  The problem is when I turn down Delays 1, 3, 4 and only use Delay 2, I have no output.  Same if I turn down 1, 2, 3 and use 4.  No output.
    Delays 1 & 3 seem to pass signal and delay as expected.  Panning on 1 & 3 work fine, I can move the signal to either side.  I have other effects running that all work and I’ve confirmed my physical patching is OK.
